RB-411AH
Hello!
I have an AP (base station) with RB-411AH and RB52H. Operation band is 2Ghz with a 120º sectorial antenna.
Actually this AP has 50 registered clients. RB-411AH is acting with mangle rules and queue tree.
I read in some forum that RB-411AH can serve more than 100 clients. But actually the response time from a client to ap is 400ms average, and the navegation at certain hours is too slow.
Can anybody give me some advice to solve this issue?
BR!
50 is too many. I personally wouldn’t go over 30-35. Depending on the amount of bandwidth you need to provide, you might not want that many.
Thanks for your response!
I think to replace this RB411AH with a RB433AH.
Do you think RB433AH can support 50 clients?
BR!
It’s not the routerboard, it’s about the radio’s…
Tks Inox,
So, what would be the better practice to do?
An RB433AH with two radios or: two RB411AH each one with an RB52H?
Thanks a lot!
I would do two 411ah with two r52hn cards. Having multiple cards on the board on the same band can cause you problems.
RB711 2HND has more power(30dbm) and 2 pcs is better than one RB433AH or any(R52HN has 25dbm). Two radios will always be better than one. More speed and lower ping.
Ok, tks cbrown and InoX.
BR!
