Hi There,
Question.
I have a setup with 2 RB433AH with a R52N in each board.
I have done good udp tests with my modulations both at 300 HT. Perfect… but as soon as we try to push tcp traffic the cpu will overload a at 43Mbits clocked at 680Mhz and stop at 50 Mbits at 800Mhz. This is a full duplex test!
I have also built a rb433 AH with 2 r52N cards in each board setup as a nstreme dual. Got it working but again no real performance gain! It does the same or poorer job than running with r52 cards! Is this a tweaking thing that can be done at driver level to make things work smoother or do the N cards just eat up more Mhz of Cpu?
It seems the cpu is the bottleneck, what other cpu’s /boards would you say we should try? Looking for BIG cpu power i think:)
Any help is welcome guys
Nic
