RB 433 LD501-LD504 Permanently On
Hi All,
I have RB433 board which failed to boot up.
LD501, LD502,LD503 & LD504 remain ON after power.
I have used the reset button and S301 but no result.
Please advice!
I have couple of device with similar symptoms, if button not help to load backup boot loader usually processor is broken.
Try first with netinstall via serial
You can look wat happend
See here for step by step procedure
http://www.wirelessinfo.be/index.php/mikrotik/pages/seriale
Let me know of the problem is solved
Thanks for your offer, nothing displayed via console
It look the routerboard is dead.
Look for Bad caps/elkos
Change them to new ones
