My RouterBoard 450g dont beeb signal during boot.
Serial cable connection does not effect, dial no connect.
Reset dont work. I Press reset button during boot, but LEDs blink only one in first second. It dont have result.
Reset hole too.
I reset in acceord this manual http://wiki.mikrotik.com/wiki/Manual:Password_reset
Serial connetction parameters - - COM1 - 115200 bits/s - 8 data - 1 stop - no parity.
Previous connection with this parameters was successfull.
RouterBOOT-2.39
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
r - reset booter configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - do memory testing
x - exit setup
your choice: p - boot protocol
RouterBOOT-2.39
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
e - format nand
i - board info
p - boot protocol
b - booter options
x - exit setup
your choice: b - booter options
Select which booter you want to load:
1 - load regular booter
2 - force backup-booter loading
your choice: 1 - load regular booter
RouterBOOT-2.39
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
e - format nand
i - board info
p - boot protocol
b - booter options
x - exit setup
your choice: o - boot device
Select boot device:
e - boot over Ethernet
n - boot from NAND, if fail then Ethernet
1 - boot Ethernet once, then NAND
o - boot from NAND only
b - boot chosen device
f - boot Flash Configure Mode
3 - boot Flash Configure Mode once, then NAND
your choice: n - boot from NAND, if fail then Ethernet
RouterBOOT-2.3
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
u - cpu mode
f - cpu frequency
e - format nand
i - board info
p - boot protocol
b - booter options
x - exit setup
your choice: x - exit setup
writing settings to flash… OK
after this happen problem.
Why in begin log “RouterBOOT-2.39” but last log menu - “RouterBOOT-2.3”?
Reset button don’t work, holding its don’t give result. Ports LEDs Blink only one - when Power on with and wirhout holding reset button. But in section “Routers/Drives” in program Netinstall router don’t show up. Port LEDs don’t lighting, side LEDs lighting. There is no beep signals.
Have you tried other baud rates in HyperTerminal? For example, 9600 bits/s to see anything in terminal while RB450G boots.
If there is no output, only solution is prepare Netinstall on PC, connect PC to ether1 port of RB450G and reset it with reset hole in order to connect to Netinstall after backup booter loads.
Try different metal objects to cover both sides of reset hole, because sometimes it is quite tricky with screwdriver.
How make prepare Netinstall on PC, what “Client IP adress” in “Net booting” button?
After reset router takes default ip?
I give him file system-5.20-mipsbe.npk and other 5.20 packages, its right?
Set static IP on PC, for example, 10.0.0.1, netmask - 255.255.255.0 and in Netinstall “Client IP adress” - 10.0.0.2
Your router does not seem to be able to boot in RouterOS, so it does not take default IP address. In this case, the point of reset is connecting to Netinstall and getting Client IP from Netinstall.
