Hi Guys,
I am newbie for Mikrotik RB.
I have an issue for accessing local Web Server through browser (http) using IP address.
The server has 3 IP address on 1 ethernet, these IP are:
10.10.10.2 /24
10.10.20.2 /24
10.10.30.2 /24
Gateway 10.10.10.1
The Issue:
While the server using gateway 10.10.10.1, client PC from IP 10.10.10.10 /24 can access WEB link with IP 10.10.10.2, But can not access Web with IP 20 or 30.
When the server gateway changed to 10.10.20.1, client PC that can access to WEB link is client from IP 20. Client from IP 10 and 30 can not access.
Question:
Can i use RB’s port as TRUNK then connect this port to the server ?
So client PC from network 10, 20, 30 can access WEB using IP those 3 web IP.
If possible, please advice how to configure the RB 450G.
Thank you very much for the response.
