steps :
New Terminal
system routerboard
update \ do you want confirm update ( y : n ) y
firmware update successfully
and give me massage ( please reboot for take an effect ) device reboot BUT NOT START AGAIN ALL DOWN Ethernet down and wireless and cant access the device
What happened was a mistake in something this big problem for me I hope you can help
If the Ethernet ports are all down - you will need to log in with a serial cable - if you can’t log in - reboot with serial cable attached and see how far through the boot process you get - it is also possible to reload the firmware via the serial cable
As written, you need to attach a serial cable to your RB and see first what’s happening using a terminal program.
If you have this data then it is possible to go on further.
Just start a terminal set to 9600 1N8 connected to your RB and power it on and see what is shown there.
