I´ve got a Problem while trying around with my Routerboard.
First of all: Everything is fine and work as desired.
But I want something special on my Routerboard: Routing of all http (80 only) to a VPN Provider.
Tool of choice is IPVanish. I have an account by them and want to use this service for http traffic only.
So therefore I have set up an additional interface (OVPN/PPTP/L2TP) with the Server I want to use, as well as my credentials. Also I have transfered the cert. Only OVPN Client worked, but I see in the Log: “attempt connection… terminated…” I can´t figure out, what the problem is.
So does anybody have had setup an IPVanish account (HideMyAss may be the same) to use with the routerboard?
If so: Could you please help me to set up mine?
When VPN then finally is ready, setup and working, how to redirect all 80´s http traffic through this tunnel, all other to normal uplink gateway?
Has anyone been able to get this to work? I know I can get it working inside of pfsense in about 10 minutes; Knowing that mikrotik is almost infinitely configurable, you’d think someone would have figured out a method that works by now!
