RB 750 DEAD ???
Hi all
Im using this board for about 7 months and from today i got all 5 leds working open and i cant comunicate with it.
I try reset but nothing change - i try another PSU and i get the same results.
The ACT led goes off after power on RB
Any help??
Promblem found !!
FAULTY CAPASITORS
Is it Suscon SJ series capacitors?
Yes!
I replace them with same brand only this time i put 1000 uf instead of 560 uf they had-i will have any promblem?
I think no, this capacitance can vary in big range without any problem.All new production use Suscon MG series - it provide three times longer life time and I hope quality can be much better.
I think I have the same problem. I think it may too be capacitors.
please contact the seller to exchange this device for a new one
they say out of warranty
then you can find someone with soldering skills and replace the mentioned capacitors yourself, this should be quite an easy task
I think I will, my 30w radioshack solder iron, is not enough for circuit boards, and my torch is too much lol
