Hi there,
I see in the log a lot of errors for login. Is this something to be worried about? And if so should I be amending the firewall settings?
Thanks!
# Time Buffer Topics Message
10 Jan/07/1970 10:36:05 memory system, error, critical login failure for user support from 77.247.181.165 via ssh
11 Jan/07/1970 10:47:22 memory system, error, critical login failure for user admin from 208.12.64.15 via ssh
12 Jan/07/1970 17:03:35 memory system, error, critical login failure for user leonob from 60.199.196.144 via ssh
13 Jan/07/1970 17:03:39 memory system, error, critical login failure for user ftpuser from 60.199.196.144 via ssh
14 Jan/07/1970 17:03:43 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
15 Jan/07/1970 17:03:47 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
16 Jan/07/1970 17:03:51 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
17 Jan/07/1970 17:03:56 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
18 Jan/07/1970 17:03:59 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
19 Jan/07/1970 17:04:04 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
20 Jan/07/1970 17:04:08 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
21 Jan/07/1970 17:04:12 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
22 Jan/07/1970 17:04:16 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
23 Jan/07/1970 17:04:20 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
24 Jan/07/1970 17:04:24 memory system, error, critical login failure for user oracle from 60.199.196.144 via ssh
25 Jan/07/1970 17:04:28 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
26 Jan/07/1970 17:04:32 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
27 Jan/07/1970 17:04:36 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
28 Jan/07/1970 17:04:41 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
29 Jan/07/1970 17:04:45 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
30 Jan/07/1970 17:04:49 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
31 Jan/07/1970 17:04:53 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
32 Jan/07/1970 17:04:57 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
33 Jan/07/1970 17:05:01 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
34 Jan/07/1970 17:05:05 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
35 Jan/07/1970 17:05:10 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
36 Jan/07/1970 17:05:14 memory system, error, critical login failure for user oracle from 60.199.196.144 via ssh
37 Jan/07/1970 17:05:19 memory system, error, critical login failure for user oracle from 60.199.196.144 via ssh
38 Jan/07/1970 17:05:23 memory system, error, critical login failure for user oracle from 60.199.196.144 via ssh
39 Jan/07/1970 17:05:28 memory system, error, critical login failure for user bwadmin from 60.199.196.144 via ssh
40 Jan/07/1970 17:05:32 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
41 Jan/07/1970 17:05:36 memory system, error, critical login failure for user cacti from 60.199.196.144 via ssh
42 Jan/07/1970 17:05:40 memory system, error, critical login failure for user test1 from 60.199.196.144 via ssh
43 Jan/07/1970 17:05:43 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
44 Jan/07/1970 17:05:47 memory system, error, critical login failure for user git from 60.199.196.144 via ssh
45 Jan/07/1970 17:05:52 memory system, error, critical login failure for user git from 60.199.196.144 via ssh
46 Jan/07/1970 17:05:56 memory system, error, critical login failure for user mysql from 60.199.196.144 via ssh
47 Jan/07/1970 17:06:00 memory system, error, critical login failure for user mysql from 60.199.196.144 via ssh
48 Jan/07/1970 17:06:03 memory system, error, critical login failure for user root from 60.199.196.144 via ssh
49 Jan/07/1970 17:26:55 memory ssh, info client timeout
50 Jan/07/1970 17:47:16 memory system, error, critical login failure for user admin from 91.236.116.157 via ssh
51 Jan/07/1970 17:47:18 memory system, error, critical login failure for user admin from 91.236.116.157 via ssh
52 Jan/07/1970 17:47:20 memory system, error, critical login failure for user admin from 91.236.116.157 via ssh
53 Jan/07/1970 17:47:22 memory system, error, critical login failure for user admin from 91.236.116.157 via ssh
54 Jan/07/1970 17:47:23 memory system, error, critical login failure for user admin from 91.236.116.157 via ssh
55 Jan/07/1970 17:47:25 memory system, error, critical login failure for user root from 91.236.116.157 via ssh
56 Jan/07/1970 17:47:28 memory system, error, critical login failure for user root from 91.236.116.157 via ssh
57 Jan/07/1970 17:47:29 memory system, error, critical login failure for user root from 91.236.116.157 via ssh
58 Jan/07/1970 17:47:32 memory system, error, critical login failure for user root from 91.236.116.157 via ssh
59 Jan/07/1970 17:47:33 memory system, error, critical login failure for user ubnt from 91.236.116.157 via ssh
60 Jan/07/1970 17:47:35 memory system, error, critical login failure for user ubnt from 91.236.116.157 via ssh
61 Jan/07/1970 17:47:37 memory system, error, critical login failure for user ubnt from 91.236.116.157 via ssh
75 Jan/08/1970 02:00:38 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
76 Jan/08/1970 02:00:41 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
77 Jan/08/1970 02:00:43 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
78 Jan/08/1970 02:00:45 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
79 Jan/08/1970 02:00:47 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
80 Jan/08/1970 02:00:49 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
81 Jan/08/1970 02:00:51 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
82 Jan/08/1970 02:00:53 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
83 Jan/08/1970 02:00:55 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
84 Jan/08/1970 02:00:57 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
85 Jan/08/1970 02:00:59 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
86 Jan/08/1970 02:01:01 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
87 Jan/08/1970 02:01:03 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
88 Jan/08/1970 02:01:05 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
89 Jan/08/1970 02:01:07 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
90 Jan/08/1970 02:01:09 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
91 Jan/08/1970 02:01:11 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
92 Jan/08/1970 02:01:12 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
93 Jan/08/1970 02:01:14 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
94 Jan/08/1970 02:01:16 memory system, error, critical login failure for user root from 78.135.93.249 via ssh
