RB-750G shows Ether2-Gateway-Master at 10Mb
I have an RB-750G and I was looking at the ethernet port speeds it had negotiated with the connected devices. I took a look at Ether2-Local-Master (port 2) and I noticed it was saying it was connected at 10Mbs half duplex even though I didn’t have anything plugged into port 2. I realize that Ether2-Local-Master is probably just showing that it’s connected because of some necessity to be or appeared connected when things are connected to the switch slave ports and nothing is connected to the master port, but that it was indicating 10Mbs had me concerned. I would assume I’m still going to get wire speed through the ports 3-5 even though nothing is in port 2. Is it important to make sure something is in port 2?
Below are screen shots.
No, it is not important. Ether2 is master-port and link ok indicates that switch group is running. Transmission parameters are not important in this case.
Thanks! I was guessing that but it’s nice to have it confirmed.
Greg
