is there a way to disable the reset jumper and the reset button on a RB 750GL?
I’m planning to deploy some of these boards and the users should not have a chance to reset them…
- Zaesch
/system routerboard settings set enable-jumper-reset=no
that’s too simple…
A big THANKS to cbrown!
