RouterBOARD 750G r3
This model has flash and ram storage.
I created some directories on the flash part and now I can’t delete it.
Help?
tried /file remove but nothing works.
tried putting files into the directories and delete, no luck.
RouterBOARD 750G r3
Help?
Did you try remove from console? with /file remove command
yes
I also can not change my hotspot loging page on rb750gr3 , i delete my all files but when rb reboot files will be there … and default login page disply on user end ..
almost 4 years later you FINALLY fixed the problem on 6.47.9. sigh.
