RB 750UP as POE Switch
Hi folks,
Can we use RB750UP as a switch. Actually I have a few sites where the AP’s tend to hang. They need to be rebooted and then everything is normal. those sites are not human managed and in remote areas where it taks like 4 hrs to reach.
I was looking for a smart POE switch with network access. Could not find a reasonable product and then I saw RB750 UP.
Disabling and enabling ports of the POE switch should reboot the AP’s connected to each port.
Any alternate system if users can advise is welcome.
Regards,
We have deployed two 750UPs to simplify installations (eliminates four power supplies & cords, four PoE injectors,and four patch cables!), but have also used it once or twice to power-cycle a board. As long as your link to the 750UP does not go through the board you are cycling :wink: it’s pretty straightforward.
