rb 751 getting ip address from dhcp
rb 751 getting ip address from dhcp server on eth1 even though there are static ip addresses on tht interface.
It shouldn’t? Likely you forgot to disable dhcp-client on that interface.
Yep, you just need to disable the dhcp client.
/ip dhcp-client disable [find where disabled=no]
