I’m trying to connect to my USB drive connected to RB 751 using SMB. From Windows everything works fine, but trying to connect from Mac (OSX 10.8.2) I get info: Server version you are trying to connect is not supported, but then connecting to Windows PC, everything works fine. Is this possible flaw that can be corrected on Mikrotik side, 'cause I don’t believe that Apple would do anything about that issue
RouterOS uses SMB v1. In MacOS 10.8 Apple completely dropped support for SMB v1 and only works with SMB v2. For MacOS 10.7 or older, this solution works: http://support.apple.com/kb/HT4697?viewlocale=en_US but not for MacOS 10.8 until we rewrite our implementation to SMB v2
One way to do it partially in os-x Mountain Lion is to install separate SAMBA with brew (sudo brew install samba) and then i can use samba utilities provided to list the shares and actually get and put files on them via samba client. Guess it is better than nothing but it still does not allow to mount the shares as smbmount is not present in SAMBA versions that are available for installation with brew.
Anyway here’s a suggestion to Mikrotik
in router management page: IP > SMB replace to IP > SMB 1.0 as this will save users hours of googling for the issues they might face as this is antique version anyway.
in your product information sheet also provide the version of SMB as this would save dumbasses like me who bought the router for gig ethernet and SMB to do timemachine backups remotely. $80 router price + $80 external hdd price is still cheaper learning price than timecapsule but hey it is not working. Only later you find out that it does not work with OS-X (starting from OSX-LION) out of the box. Cause the documentation does not say a thing about the versions
anyway lets hope that Mikrotik will upgrade the SMB version in someday cause other aspects of the router are quite good.
