rb-800
i have a problem on my rb-800 could be access on winbox. and when i use to connect the router board on serial port it could not also detected on the computer. can you help me on my problem. thanks…
Is this the only Routerboard that you have problem accessing via serial port? Make sure you serial terminal baud-rate is set to 115200.
