RB 912UAG-5HPnD and MC7710
I connected a Sierra Wireless MC7710 module to a RB 912UAG-5HPnD with RouterOS 5.26.
The command:
/system resource pci print
doensn’t show any pci hardware, and no LTE interface is shown under LTE Interface section in WinBox.
What I can check more?
Thanks, Diego
you might want to upgrade your router to latest 6, and then try again
before check if your hardware is supported:
http://wiki.mikrotik.com/wiki/Supported_Hardware
cheers
It won’t show up under pci-devices. Sierra card is usb-device and it will shou under usb.
[admin@MikroTik] > /system resource usb print
 # DEVICE VENDOR                    NAME                   SPEED
 0 1:1    Linux 3.3.5 ehci_hcd      RB400 EHCI             480 Mbps
 1 1:2    Sierra Wireless, Incor... MC7710                 480 Mbps
But first you have to change routerboard usb setting to use mini-PCIe usb port.
/system routerboard usb set type=mini-PCIe
That’s solved.
Thank you very much.
Diego
