RB 91G2HPnd and MC7430 doesn't work?
Hello
I’m trying to work with my MC7430 and the RB doesn’t “know” him…
nothing on the usb , port , resources
any reason why?
if I take the same modem and put it on RB411U - it does show…
any explain why?
Thanks ,
Perhaps you mean a RB912UAG-2HPnD?
Have you tried taping the USB 3.0 pins?
Read here for details
yes
I have “remove” the USB3 pins and now i can see the modem
the problem now is that it disconnecting all the time
working for 4-5 seconds and disconnect , work 4-5 seconds - disconnect…
the signal is good
-73 dBm
LTE
any idea why ?
Read the thread I linked earlier.
All of it.
I have did everything it say
disable the usb3 pins , and try to run the scripts
but still it get disconnected after 4-5 seconds
Perhaps try keep it simple, lets get rid of the scripts for now.
Just try the following.
system resource usb print
Should spit out something like this.
DEVICE VENDOR NAME SPEED
0 2:1 Linux 3.3.5 ehci_hcd RB400 EHCI 480 Mbps
1 1:1 Linux 3.3.5 ehci_hcd RB400 EHCI 480 Mbps
2 1:2 Sierra Wireless, Incorporated Sierra Wireless MC7430 Qualcomm\C2\AE Snap... 480 Mbps
Depending on how many buses etc your routerboard has you need to issue the following command but need to change the bus number to suit your situation.
I've underlined what I think is the bus number on my routerboard.
system routerboard usb power-reset bus=1 duration=5
If that doesn't work try longer or shorter usb bus resets.
Also try the modem in a laptop if you have one available. Mine worked excellent in a laptop with kali linux for an OS.
now it’s working ..
It hasn’t disconnected for 15 min now
so I will put this script at startup and give it a try for a few days
Thanks !
