Hello everyone am new here,
I’m trying to configure my rb951 to access Internet from ISP router but after setting the static IP ( 192.168.100.100/24) and checking routes and when I try to ping google.com it displays this “admin@MikroTik] > ping www.google.com
invalid value for argument address:
invalid value of mac-address, mac address required
invalid value for argument ipv6-address
while resolving ip-address: could not get answer from dns server of”
Please share the config to get some relevant feedback:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
Does your ISP support DHCP as means of obtaining IP config for clients? If it does, then use it, it’s usually less error-prone than static setup.
According to error messages you posted it’s likely that you didn’t set IP address(es) of DNS servers for router to use.
