Hey guys,
My RB951G was working fine for a while but then suddenly went down one evening. It stopped transmitting WiFi and couldn’t connect to it over LAN.
Tried turning the power off and on but didn’t work. So tried resetting the config from the front panel and didn’t work, tried from the reset jumper hole in the bottom and that didn’t work either.
So I put it into PxE boot mode and connected it to Netinstall. But when I select the router and the package file it just says “Partitioning and formatting harddrive…” and stays that way. The program is still responding but nothing is happening.
Any idea what’s wrong?
