Hello.
I want to schedule WIFI access on my router. I found help at http://forum.mikrotik.com/t/create-schedule-for-wifi/29291/1 and made all the steps. Scripts work and schedule also works.
But I found out later: when I switch OFF wlan1 I can’t get access to ethernet ports. Suddenly all ethernet ports are frozen and I must reset it to default. Of course, I tried to delete scripts, schedule and reset to defaults. Everything works fine till I disable wlan1. Disabling wlan1 directly from /wireless/ setting also freeze ethernet ports on router.
Routerboard type is RB 951G-2HnD (firmware 3.04) and software version is 5.24.
Thank you.
