RB 951G Question
Hi All
I did some searching on the forum but was unable to find a relevant post. Probably due to a lack knowledge.
I have a RB951G that I have used as a Wifi and wired router to give internet access to my home network. To date I have used a PPP connection to a 3g USB modem but I want to connect to LTE. I do not have a compatible LTE usb modem but I have a Huawei B593 LTE Router. I want to continue using the RB951 as it is far superior to the B593. I just want to use the B593 to get access to LTE.
I have disabled the Wifi and DHCP on the Huawei router and would like to use an Ethernet connection between the two routers to give access to the LTE network. Can anyone help me with the correct settings on the RB951. Do I create a bridge or what method could I use.
Any assistance would be greatly appreciated
Sorted
I want to do the same thing, can you say how you sorted it?
