Hello
I tried to configure my RouterBoard and CRS according to: http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Port_Based_VLAN
my present configuration of CRS is:
[admin@MikroTik] > export
jan/02/1970 03:24:21 by RouterOS 6.34.4
software id = BSUC-CLB7
set [ find default-name=ether1 ] name=ether1-master
set [ find default-name=ether2 ] name=ether2-trunk
set [ find default-name=ether3 ] master-port=ether1-master
set [ find default-name=ether4 ] master-port=ether1-master
set [ find default-name=ether5 ] master-port=ether1-master
set [ find default-name=ether6 ] master-port=ether1-master
set [ find default-name=ether7 ] master-port=ether1-master
set [ find default-name=ether8 ] master-port=ether1-master
set [ find default-name=ether9 ] master-port=ether1-master
set [ find default-name=ether10 ] master-port=ether1-master
set [ find default-name=ether11 ] master-port=ether1-master
set [ find default-name=ether12 ] master-port=ether1-master
set [ find default-name=ether13 ] master-port=ether1-master
set [ find default-name=ether14 ] master-port=ether1-master
set [ find default-name=ether15 ] master-port=ether2-trunk
set [ find default-name=ether16 ] master-port=ether1-master
set [ find default-name=ether17 ] master-port=ether1-master
set [ find default-name=ether18 ] master-port=ether1-master
set [ find default-name=ether19 ] master-port=ether1-master
set [ find default-name=ether20 ] master-port=ether1-master
set [ find default-name=ether21 ] master-port=ether1-master
set [ find default-name=ether22 ] master-port=ether1-master
set [ find default-name=ether23 ] master-port=ether1-master
set [ find default-name=sfp1 ] master-port=ether1-master
/interface vlan
add interface=ether2-trunk name=ether2-vlan200 vlan-id=200
add name=pool-test ranges=192.169.100.10-192.169.100.250
add address-pool=pool-test disabled=no interface=ether24 name=dhcp-test
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether2-trunk,ether15 vlan-id=200
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=200 ports=ether15
add ports=ether2-trunk,ether15 vlan-id=200
add address=192.168.88.1/24 comment=defconf interface=ether1-master network=192.168.88.0
/system routerboard settings
set protected-routerboot=disabled
[admin@MikroTik] >
on the Trunk side (RouterBoard) i have such configuration:
/interface vlan add interface=ether10 name=vlan100 vlan-id=100
/interface vlan add interface=ether10 name=vlan200 vlan-id=200
plus configuration for dhcp on router board vlan200:
/ip dhcp-server add address-pool=pool-tmp disabled=no interface=vlan200 name=dhcp-200
Port ether10 of RouterBoard is connected to ether2-trunk CRS port. When i connect computer to ether15 it can’t recive address from dhcp server. What is strange, when i manually create vlan 200 on port ether2-trunk and setup dhcp-client on this port it is reciving ip how it should. So it looks like problem is with vlan packets forwarding to corrects ports. What am i doing wrong? What else should be configured/corrected?
Best regards
holo
