RB Boards - "Files" is empty!
Hello All,
I have many different routerboards with all different versions of OS on them. However, no matter what winbox loader I use the files list is empty! No files at all, I can do a backup and see that file, but nothing else.
I am trying to access the hotspot pages to modify.
Any Suggestions? Am I missing rights or a setting somewhere, currently using the admin user (default).
Thanks!
Adam J
theWISP.net
Do you have a hotspot set up on any of the interfaces? If not, then they won’t be there. When you do set it up, they will show up as “hotspot/*”
Yes, I it setup. But shouldnt I see some files in the files window? I see nothing.
Also, if the hotspot is setup but disabled will the files still be there?
Thanks,
Adam
Now there is a good question. If it has always been disabled, I don’t know. Normally, if it was set up enabled, and then disabled, they should still be there.
ADD: I use this to set up my hotspots:
/ip hotspot setup
and answer the questions.
Yea, thats what I have done. And I have done the reset html pages as well. But still NO files at all in the files window, I am not only missing the HOTSPOT files, but all files.
Never seen that. Then I have a couple questions:
What hardware is this on?
What RouterOS version are you using?
What level license does the hardware have?
It is RouterOS 3.17 on a wrap board. Looks like maybe my flash card is full…hmm.
RouterOS runs on a WRAP board? I am amazed! :smiley:
I have no experience with RouterOS on anything but RB products or x86 machines.
