I purchased 2 Crossroads brand new out of the box.
After reading the manual, I opened up JP2 to allow for higher voltages to power the device. I used a 48V POE Injector. On both boards. Using POE the device does not power on at all, yet, putting the 48V Power directly into the power socket, the router works flawlessly.
After reading the documentation, I’m stumped as to why POE does not work, and I’m just as stumped at the confusing documentation provided as to whether POE actually works or not on the Crossroad boards…
I’m going to try a different injector tonight, and if that doesn’t work well then I don’t really have any option but to remove said components. I’ll shout if I don’t come right and we can look at removing ‘some parts’ Which begs the question, why not just remove them from the start, and cut the costs of the board some more?
Tried two POE injectors now, neither works… Can you maybe just share the details with me so I can give it a try to see whether I can get it working please? It’s a real pain that POE isn’t working (like it should).
