RB Crossroads - superchannel license
Is there a superchannel license available for install on RB Crossroads ?
I mean, is FCC certified. Can we use the rest of the channels ? Does mikrotik allow that ?
With license of course ?
as usual, if you do have proper permissions from your government to use these additional (outside FCC?) frequencies, let us know and we will give you this.
I live in CE.
I use legally at least one channel vs. FCC.
Will there be a FCC or CE cert. for other products ?
( Yes, I know, parts like wireless minipci cards are certified by the producer. )
We do, and use these outside the US in a couple of cases.
How can we arrange to get this?
Ray
contact support of mikrotik
I did, they want ME to provide them with the documentation from
the countries in question…
They need to research this themselves if they are going to lock things
down as far as allowed frequencies in various countries.
We have a couple of fixed links in other countries that won’t work
under 3.2. I asked what they changed and they evaded the question.
I guess they only want to support “public” frequencies. Some of these
are licensed.
Ray
Would it be much more complicated to add an ETSI package for the radio, for use in Europe ?
( similar to the wireless-crd package ? )
We are using the standard ETSI lists. If something changed, it means the ETSI list changed. If you have some special permission outside of official lists, you have to explain and we will give you ability to use the custom frequency license upgrade
Obviously I have to use custom frequency (after buying the license) on a lot of routerboards.
How is it managed ?
When I buy the license + custom frequency how it will be applied to all routerbords ?
Carlo
I have more than 15 routerboards to put on a custom frequency…do I need a plus charge on each routerboard ?
Carlo
