Does exist a RB that has 2 modules radio (24 and 5 Ghz) already installed?
No. Only “custom build” solutions at this time.
OK, the best solution which component it uses?
Right now I would use a 433 with two R52Hn.
Ok. RB433 or RB433AH ?
It’s very similar board. AH version have better/faster CPU. Depends what your requirements are. Probably both would satisfy your needs.
As an alternative to 433:
- RB411AR + R52Hn
- RB912UAG-2HPnD + RB 11E (hopefully out soon)
