Rb Groove has lost its sensitivity ???
Why Rb Groove has lost its sensitivity ???
Always my Groove shows the WDS AP 4C:5E:0C:C4:41:BF with -46, after a raining day the sensitivity rx was fallen down, now my Groove shows the same WDS AP only with -68 ??? The WDS Distance is only
300m !
If the signal degrades after rain then something is wet.
Check that the LMR cables is properly sealed with Butyl Tape(we call it ape shit)
Also you can put non drying silicon in the connectors.
But I think you issue is water getting in where is shouldn’t
I do not use Antena Cable, the Antena is connected direct to the Groove, it’s isolated with high voltage tape, rubber tape!
The tape should be self-vulcanizing otherwise the water finds its way in. Take it down, dismount, dry and test again. If the result will be good, use good tape to protect the connector against water. Also seal the closing cap and leave the bottom holes open.
Something else you could check is close objects like a tree.
If the tree gets wet the signal gets reflected more, had this issue with installs done in the winter months.
As soon as the tree grows leaves and it rains the signal degrades
