RB HDD Size 64MB
How to fix HDD Size? it should be 128MB
Tnx.
According to this NAND size is 64M so you don’t need to fix anything.
Hmm I got 6xRb600A and 5 of them are with 128mb
Than you should be asking how to fix those routerboards to show 64MB instead 128MB :smiley:
Seriously, the spec sheet shows what you should get, anything more you can consider as a bonus. For example I have old RB433AH with 512MB and new with 64MB…
the RB600 has 64mb and RB600A has 128
You’re right (http://routerboard.com/pricelist.php?showProduct=55) RB600A should have 128MB…
