Health Graphing
Submenu level: /tool graphing health
Description
This submenu provides information about RouterBoard’s ‘health’ - voltage and temperature. For this option, you have to install the routerboard package:
According to the excerpt from the manual, I have to install the “routerboard” package. What is that and where do I find it?
arizonajon,
probably documentation does not provide clear explanation,
but temperature settings are available only for RB200 boards,
[admin@RB] system health> print oid
core: .1.3.6.1.4.1.14988.1.1.3.1.0
3.3v: .1.3.6.1.4.1.14988.1.1.3.2.0
5v: .1.3.6.1.4.1.14988.1.1.3.3.0
12v: .1.3.6.1.4.1.14988.1.1.3.4.0
cpu-temp: .1.3.6.1.4.1.14988.1.1.3.6.0
board-temp: .1.3.6.1.4.1.14988.1.1.3.7.0
RB500 boards do not have such menu ‘system health’, there is no such information provided.
Well that probably explains why I can’t find that command in my RB112. Too bad, as I really like having those properties telemetered here in Arizona.
So how many differences will I find between what I have in the RB112 and the RB133 which I just ordered? It doesn’t look like I can trust the manual. How about a note by each command that says what h/w supports it?
/system package print
should show routerboard enabled or disabled. It’s part of the whole package.
I suspect the RB1xx/RB5xx doesn’t have the system health options. I have a PC that lets me at that configuration section and OIDs but doesn’t display any data. Maybe it’s just for RB2xx?
You can use it only in RB200 series (maybe using boards with specific chip too).
It is mentioned in manual:
System Health Monitoring
Submenu level: /system health
Description
LM87 health controller chip provides some measurments of temperature and voltage on RouterBOARD 200 series computers. Information becomes available not sooner than 2 minutes after boot up. It is not available if LM87 chip is not detected successfully…
