RB Matel G-52SHPACN
ERROR: could not connect to 192.168.88.1,able to ping ip but cannot able to open device in web winbox telnet ssh,.’
version:6.40.8(bugfix) can anyone support for login..
Do you see the router in Winbox Neighbors once you are connected via wireless or ethernet cable? If that is the case, are you able to connect by mac-address? If the Metal is not broadcasting any SSID, you can reset it to default settings by holding reset button before powering it up. Keep it pressed until LED light starts flashing (usually around 5-10 seconds)
[/quote]
In winbox we can able to view neighbour but cannot able to connect to mac address and ip address.Reset is done more than 6 times.but even though we cannot able to connect.
I recommend contacting MikroTik support, they should be able to resolve your issue.
https://mikrotik.com/support
Reset the device to defaults or make netinstall of latest long term version.
