RB Net Access by Voucher Cards?
Hi there,
has any of the RouterBoards implemented to use voucher cards as methods of log in?
that would be the best move forward from mikrotik if they will make it possible!
Thank You,
http://wiki.mikrotik.com/wiki/User_Manager/QA/How_to_create_timed_Voucher
Also search the forums for “voucher”, there’s plenty of threads.
i’m sorry.. this is so cool, but i don’t find it on my mikrotik!
system > license = level 4
RB433.
I am thinking about buying RB800 soon.. would that have this credit functionality?
thanks,
User Manager is an add on you can install on RouterOS. You can find the documentation on the wiki.
Download the following file, http://download.mikrotik.com/all_packages-mipsbe-4.10.zip. Follow the information described in Upgrading RouterOS - Upgrade Process to add the package. If you’re already running 4.10 just copy over user-manager-4.10.npk.
Hope this helps.
I have tried on routeros 5.0beta5 and is not working. I cannot access that webpage after I have created a user from console.
