I am having trouble getting traffic to flow between the LAN and WLAN ports of my RB SXT 5nD r2 (OS 6.27).
If I use the Quick Setup it configures a bridge and traffic flows fine.
The configuration I need to use is to have a firewall between the LAN and WLAN ports (making the LAN side the WAN or outside of the firewall and the WLAN the inside or safe side).
Please find below a dump of my config and I would really appreciate any suggestions - I am not even sure if OS licence level 3 (which is what comes on the SXT) has the ability to do what I want to do?
Regards,
Daniel Jansen
apr/15/2015 17:32:20 by RouterOS 6.27
software id = 0E7J-YX6S
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-ht-above country=australia dfs-mode=no-radar-detect disabled=no l2mtu=2290 mode=bridge name=wlan1-gateway nv2-preshared-key=******************* nv2-security=enabled
wireless-protocol=nv2
set [ find default-name=ether1 ] name=ether1-local
/ip neighbor discovery
set wlan1-gateway discover=no
add name=default-dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=default-dhcp disabled=no interface=ether1-local name=default
add address=192.168.88.1/24 comment="default configuration" disabled=yes interface=ether1-local network=192.168.88.0
add address=192.168.10.250/24 interface=wlan1-gateway network=192.168.10.0
add address=192.168.1.1/24 interface=ether1-local network=192.168.1.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no
add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" disabled=yes protocol=icmp
add chain=input comment="default configuration" connection-state=established,related disabled=yes
add action=drop chain=input comment="default configuration" disabled=yes in-interface=ether1-local
add chain=forward comment="default configuration" connection-state=established,related disabled=yes
add action=drop chain=forward comment="default configuration" connection-state=invalid disabled=yes
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface=ether1-local
add action=masquerade chain=srcnat comment="default configuration" disabled=yes out-interface=ether1-local
add action=masquerade chain=srcnat disabled=yes src-address=192.168.1.0/24
add action=masquerade chain=srcnat disabled=yes src-address=192.168.10.0/24
add distance=1 gateway=192.168.10.1 pref-src=192.168.10.250
/system clock
set time-zone-name=Australia/Sydney
/system identity
set name=LJH-Dan
/system leds
set 0 interface=wlan1-gateway
/tool mac-server
add interface=ether1-local
/tool mac-server mac-winbox
