I have two router boards that I am trying to setup IPIP tunnels with IPsec running across with OSFP. I get the tunnels up and able to pass traffic. I am able to reach both sides of the tunnel and behind the routers too. The problem is that the SA are only installed and the remote peers connection show up in IPSEC when you ping between the end of the tunnel. If I ping from private to private it doesn't create or encrypt the tunnel. Any Ideas? Config is below.
Site A
/ip ipsec proposal
set default auth-algorithms=md5 disabled=no enc-algorithms=3des lifetime=1d
name=default pfs-group=modp1024
/ip ipsec peer
add address=10.255.255.6/32 auth-method=pre-shared-key dh-group=modp1024
disabled=no dpd-interval=disable-dpd dpd-maximum-failures=1 enc-algorithm=
3des exchange-mode=main generate-policy=no hash-algorithm=md5 lifebytes=0
lifetime=1d my-id-user-fqdn="" nat-traversal=no port=500 proposal-check=
obey secret=l00ker send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=10.255.255.6/32 dst-port=any
ipsec-protocols=esp level=require priority=0 proposal=default protocol=all
sa-dst-address=10.255.255.6 sa-src-address=10.255.255.5 src-address=
10.255.255.5/32 src-port=any tunnel=no
/interface ipip
add disabled=no local-address=2.2.2.2 mtu=1480 name=TO_I240 remote-address=1.1.1.2
/ip route> print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 2.2.2.1 1
1 ADC 10.255.255.4/30 10.255.255.5 TO_I240 0
2 ADC 2.2.2.0/30 2.2.2.2 Eth2- WAN 0
3 ADo 172.15.0.0/24 10.255.255.6 110
4 ADC 172.18.0.0/24 172.18.0.1 LAN 0
Site B
/ip ipsec proposal
/ip ipsec peer
add address=10.255.255.5/32 auth-method=pre-shared-key dh-group=modp1024
/ip ipsec policy
add action=encrypt disabled=no dst-address=10.255.255.5/32 dst-port=any
sa-dst-address=10.255.255.5 sa-src-address=10.255.255.6 src-address=
10.255.255.6/32 src-port=any tunnel=no
/interface ipip
add disabled=no local-address=1.1.1.2 mtu=1480 name=TO_DEALERS remote-address=2.2.2.2
/ip route> print
0 A S 0.0.0.0/0 1.1.1.1 1
1 ADC 10.255.255.4/30 10.255.255.6 TO_DEALERS 0
2 ADC 1.1.1.0/32 1.1.1.2 Eth2 - WAN 0
3 ADC 172.15.0.0/24 172.15.0.1 Eth1 - LAN 0
4 ADo 172.18.0.0/24 10.255.255.5 110
So to summarize again. I am able to pass traffic fine I just don't think packets from 172.15.0.0 to 172.18.0.0 are being encrypted as I don't show a SA at all until I ping between the 10.255.255.x interfaces then the SA is installed.
