Hey David1234
I could just make it work here!
I’m using 912UAG-2HPnD, RoS and Firmware version 6.41
From my side, I couldn’d find it as a LTE interface, but as a PPP client interface only, so:
a) I’ve changed the USB under the System > Routerboard > USB → change from USB Type A to Mini PCI-E;
b) After that, the RB identified under System > Resources > USB:
Vendor: Android - Vendor ID: 0x1bc7 - Device: Android - Device ID: 0x1201
(This is the only strange issue… Although it works, it’s identified as Android under this menu).
c) Under Interfaces > PPP Client, I used the following configuration:
c.1) General tab:
- Change the Port to the correct usb port (in my case usb1);
**- Data channel: 4
- Info Channel: 3**
- APN: configure your APN
c.2) PPP tab
- Phone: put your carrier dial number: mine is *99#
- Dial command: ATDT
- User: put your 3G account user name
- Password: put your 3G account user name
- Unselect the “Dial on Demand Option”.
Enable the interface and apply the configurations.
After these, my RB initialized the modem, and could dial out and authenticate, and finally connected:
jan/01/2002 01:36:59 system,info device changed by admin
jan/01/2002 01:36:59 async,ppp,info ppp-out1: initializing…
jan/01/2002 01:36:59 async,ppp,info ppp-out1: waiting for packets…
jan/01/2002 01:37:08 async,ppp,info ppp-out1: connecting…
jan/01/2002 01:37:31 async,ppp,info Telit LE910-EUG: terminating…
jan/01/2002 01:37:31 async,ppp,info Telit LE910-EUG: disconnected
jan/01/2002 01:37:31 async,ppp,info Telit LE910-EUG: initializing…
jan/01/2002 01:37:31 async,ppp,info Telit LE910-EUG: reseting link…
jan/01/2002 01:37:31 system,info device changed by admin
jan/01/2002 01:37:32 async,ppp,info Telit LE910-EUG: initializing modem…
jan/01/2002 01:37:33 async,ppp,info Telit LE910-EUG: dialing out…
jan/01/2002 01:37:33 async,ppp,info Telit LE910-EUG: authenticated
jan/01/2002 01:37:36 async,ppp,info Telit LE910-EUG: could not determine remote address, using 10.112.112.
119
jan/01/2002 01:37:36 async,ppp,info Telit LE910-EUG: connected
PS.: I think the most important here is the Data and Info channel numbers.
