RB wlan ap-bridge
I am trying to get my rb work as an ap for my winxp labtob.
I setup the wlan1, can see it on the labtob, can connect.
I get an ip, the dns and the gateway.
But can not ping anything.
I the the ip route stats, i can set the routes but it is not active.
Any help ??
Regard Brian
Please read the manual…: http://www.mikrotik.com/docs/ros/2.9/
Are you trying to use NAT?
I try to connect my labtop to the wireless interface (wlan1) on the MT and then access the internet (Wan)
I use my Lan port to connect winbox to the MT
The Wan is DHCP client and the Lan, wlan1 is DHCP Server 192.168.1.0/24
My PC get ip 192.168.1.200 and the labtop get 192.168.1.199.
I can access the internet from the pc and ping the MT, but on the labtop I can not ping or access the internet.
Here is my config
set Wan name=“Wan” mtu=1500 mac-address=00:0C:42:04:9C:A7 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no
set Lan name=“Lan” mtu=1500 mac-address=00:0C:42:04:9C:A8 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no
/ interface wireless
set wlan1 name=“wlan1” mtu=1500 mac-address=00:0C:42:05:12:03 arp=enabled disable-running-check=no radio-name=“000C42051203” mode=ap-bridge ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2422 band=2.4ghz-b/g scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled
dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment=“” disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
set wlan2 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
set wlan2 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“” unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“” wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates tls-certificate=none
static-algo-0=none static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless access-list
add mac-address=00:12:F0:D7:37:11 interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key=“” comment=“” disabled=no
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
/ ip pool
add name=“dhcp_pool1” ranges=192.168.1.100-192.168.1.200
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip dns
set primary-dns=193.162.153.164 secondary-dns=193.162.146.9 allow-remote-requests=no cache-size=2048KiB cache-max-ttl=1w
/ ip address
add address=192.168.1.10/24 network=192.168.1.0 broadcast=192.168.1.255 interface=Lan comment=“” disabled=no
add address=192.168.1.11/24 network=192.168.1.0 broadcast=192.168.1.255 interface=wlan1 comment=“” disabled=no
/ ip route
/ ip firewall nat
add chain=srcnat out-interface=Wan action=masquerade comment=“Make Routes on Wan Interface” disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s tcp-time-wait-timeout=10s tcp-close-timeout=10s
udp-timeout=10s udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m tcp-syncookie=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set mms disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip hotspot service-port
/ ip dhcp-client
add interface=Wan add-default-route=yes use-peer-dns=yes use-peer-ntp=yes comment=“” disabled=no
/ ip dhcp-server
add name=“dhcp1” interface=Lan lease-time=3d address-pool=dhcp_pool1 bootp-support=static authoritative=after-2sec-delay disabled=no
add name=“server1” interface=wlan1 lease-time=3d address-pool=dhcp_pool1 bootp-support=static authoritative=after-2sec-delay disabled=no
/ ip dhcp-server config
set store-leases-disk=5m
/ ip dhcp-server lease
/ ip dhcp-server network
add address=192.168.1.0/24 gateway=192.168.1.10 dns-server=192.168.100.9 comment=“”
/ ip ipsec proposal
add name=“default” auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no
/ system logging
add topics=info prefix=“” action=memory disabled=no
add topics=error prefix=“” action=memory disabled=no
add topics=warning prefix=“” action=memory disabled=no
add topics=critical prefix=“” action=echo disabled=no
/ system logging action
set memory name=“memory” target=memory memory-lines=100 memory-stop-on-full=no
set disk name=“disk” target=disk disk-lines=100 disk-stop-on-full=no
set echo name=“echo” target=echo remember=yes
set remote name=“remote” target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 check-interval=1d user=“”
/ system clock dst
set dst-delta=+00:00 dst-start=“jan/01/1970 00:00:00” dst-end=“jan/01/1970 00:00:00”
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term=“” disabled=no
/ system identity
set name=“MikroTik”
/ system note
set show-at-login=yes note=“”
/ system routerboard settings
set baud-rate=115200 boot-delay=3s boot-device=nand-if-fail-then-ethernet enter-setup-on=any-key cpu-mode=power-save memory-test=no cpu-frequency=330MHz boot-protocol=bootp enable-jumper-reset=yes
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=no mode=unicast primary-ntp=194.239.134.10 secondary-ntp=0.0.0.0
/ port
set serial0 name=“serial0” baud-rate=auto data-bits=8 parity=none stop-bits=1 flow-control=hardware
/ ppp profile
set default name=“default” use-compression=default use-vj-compression=default use-encryption=default only-one=default change-tcp-mss=yes comment=“”
set default-encryption name=“default-encryption” use-compression=default use-vj-compression=default use-encryption=yes only-one=default change-tcp-mss=yes comment=“”
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name=“default” kind=pfifo pfifo-limit=50
set ethernet-default name=“ethernet-default” kind=pfifo pfifo-limit=50
set wireless-default name=“wireless-default” kind=sfq sfq-perturb=5 sfq-allot=1514
set synchronous-default name=“synchronous-default” kind=red red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name=“hotspot-default” kind=sfq sfq-perturb=5 sfq-allot=1514
add name=“default-small” kind=pfifo pfifo-limit=10
/ user
add name=“admin” group=full address=0.0.0.0/0 comment=“system default user” disabled=no
/ user group
add name=“read” policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!ftp,!write,!policy
add name=“write” policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,!ftp,!policy
add name=“full” policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ tool mac-server ping
set enabled=yes
