I have a ProCurve 5405zl switch, and have configured a thrid VLAN on it for internal wireless equipment.
However, I cannot get the network outside of the switch! The MikroTik’s have manual IP routes (we’re a government org., so routes are point to point and static), and I’ve added in the new VLAN route - but can’t pass traffic between the MikroTik’s and the switch.
I can post configs of the switch and router if that would help.
[admin@WAN Core Router] /routing rip> print
distribute-default: always
redistribute-static: yes
redistribute-connected: yes
redistribute-ospf: no
redistribute-bgp: no
metric-default: 1
metric-static: 1
metric-connected: 1
metric-ospf: 1
metric-bgp: 1
update-timer: 30s
timeout-timer: 3m
garbage-timer: 2m
routing-table: main
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 172.26.xxx.xxx 1
1 A S ;;; Old SMTP
10.10.0.15/32 172.28.144.128 1
2 ADC 10.10.7.0/24 10.10.7.1 ether2 0
3 A S 10.10.17.0/24 10.10.7.25 1
4 A S 10.10.20.0/24 10.10.7.25 1
5 A S 10.10.24.0/24 10.10.7.25 1
6 A S 10.10.28.0/24 10.10.7.25 1
7 A S 10.10.115.0/30 10.10.7.25 1
8 A S ;;; Customer Service VoIP VLan
10.62.226.0/23 172.28.144.193 1
9 A S 172.17.7.80/28 10.10.7.25 1
10 A S 172.17.249.0/24 10.10.7.25 1
11 ADC 172.26.xxx.xxx/30 172.26.xxx.xxx ether3 0
12 A SB ;;; BLACKHOLE
172.28.144.0/20 15
13 ADC 172.28.144.0/22 172.28.144.192 ether1 0
14 A S 172.28.148.0/24 172.28.144.205 1
15 X S ;;; DRP -
172.28.148.0/24 ether2 10
16 A S ;;; DEC Routing
172.28.149.0/24 10.10.7.13 1
17 A S ;;;
172.28.150.0/24 10.10.7.25 1
18 A S ;;;
172.28.151.0/25 10.10.7.25 1
19 X S ;;;
172.28.151.128/25 ether2 1
20 A S ;;;
172.28.152.0/25 10.10.7.25 1
21 A S ;;;
172.28.152.128/25 10.10.7.25 1
22 A S ;;;
172.28.153.0/25 10.10.7.25 1
23 X S ;;; Spare Range
172.28.153.128/25 172.28.144.192 1
24 A S ;;;
172.28.154.0/25 10.10.7.25 1
25 A S ;;;
172.28.154.128/25 10.10.7.25 1
26 X S ;;; Router in IT Area
172.28.155.0/25 ether2 1
27 X S ;;; Spare Range
172.28.155.128/25 172.28.147.129 1
28 A S ;;;
172.28.156.0/25 10.10.7.25 1
29 A S ;;;
172.28.156.128/25 10.10.7.25 1
30 X S ;;; Customer Service PC VLan
172.28.157.64/26 ether4 1
31 A S ;;; GCC WAP - LAN IP Range
172.28.158.0/27 172.28.144.193 1
32 A S ;;; GCC WAP DHCP
172.28.158.32/27 172.28.144.193 1
33 A S ;;; VPN - Staff
172.28.159.0/26 172.26.69.169 1
34 A S ;;; VPN - External
172.28.159.64/26 172.26.69.169 1
