I have an RB1000 running RouterOS 4.5 and firmware 2.20. Whenever I reboot the router from RouterOS, both the green and blue lights stay on and the router hangs. No beeps. I don’t know if it’s not shutting down or not starting back up. If I pull the power, it comes back up fine, but there’s no indication in the log of a problem.
Any output on the serial port console?
You’re not alone ddunkin.
I have a customer with the same problem. It looks like a RAM problem. We have been upgrading with Crucial RAM. Worked fine for months but now we are hearing of problems.
I found that info with a quick search through the forum…
http://forum.mikrotik.com/t/rb1000-wont-soft-reboot-resolved/35266/1
http://forum.mikrotik.com/viewtopic.php?f=3&t=32086&start=0&hilit=rb1000+reboot
I don’t understand why it only seems to affect reboot though.
Good luck,
Tom
