The RB1000 loses the time when it loses power. Is there a battery available? Or is this just an issue that can’t be resolved?
Thanks,
Cory
Thanks,
Cory
Just use NTP. it’s included in RouterOS.
Regards
Lutz
I am using ntp. The issue comes in when it isn’t able to synchronize the time before things start happening. For example any log messages that occur before the time synchronizes. I also had be graphs reset recently because the time didn’t get set.
Cory
Yes it’s a problem, seen all routerboards and it has the problem.
