RB1000 problem
I just bought RB1000 and upgraded it to ROS v3.14 and now Terminal doesn’t work correctly but winbox works fine.
I don’t get LOGIN screen…
At first in Terminal RB1000 show message:
RouterBOOT booter 2.17
RouterBoard 1000
CPU frequency: 1333 MHz
  Memory size: 512 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Using RB1000 machine description
Memory CAM mapping: CAM0=256Mb, CAM1=256Mb, CAM2=0Mb residual: 0Mb
Linux version 2.6.26.5 (build@builder2) (gcc version 4.2.1) #1 Tue Sep 16 09:39:
26 EEST 2008
Found initrd at 0x802b1000:0x802b2000
Found legacy serial port 0 for /soc8548@e0000000/serial@4500
  mem=e0004500, taddr=e0004500, irq=0, clk=533328000, speed=0
console [udbg0] enabled
Entering add_active_range(0, 0, 131072) 0 entries of 256 used
Top of RAM: 0x20000000, Total RAM: 0x20000000
Memory hole size: 0MB
Zone PFN ranges:
  DMA             0 ->   131072
  Normal     131072 ->   131072
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0:        0 ->   131072
On node 0 totalpages: 131072
  DMA zone: 1024 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 130048 pages, LIFO batch:31
  Normal zone: 0 pages used for memmap
  Movable zone: 0 pages used for memmap
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: root=/dev/mtdblock1 console=ttyS0,115200 board=mpc85xx boot
=1
mpic: Setting up MPIC " OpenPIC " version 1.2 at e0040000, max 1 CPUs
mpic: ISU size: 1, shift: 0, mask: 0
mpic: Initializing for 32 sources
PID hash table entries: 2048 (order: 11, 8192 bytes)
time_init: decrementer frequency = 66.666000 MHz
time_init: processor frequency   = 1333.320000 MHz
clocksource: timebase mult[3c00275] shift[22] registered
clockevent: decrementer mult[1111] shift[16] cpu[0]
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 516736k/524288k available (2528k kernel code, 7276k reserved, 96k data,
105k bss, 128k init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 133.12 BogoMIPS (lpj=665600)
Mount-cache hash table entries: 512
net_namespace: 628 bytes
NET: Registered protocol family 16
rstcr compatible register does not exist!
PCI: Probing PCI hardware
SCSI subsystem initialized
libata version 3.00 loaded.
NET: Registered protocol family 2
Switched to high resolution mode on CPU 0
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
Unpacking initramfs... done
Freeing initrd memory: 4k freed
beeper init
irq=31
beeper done
yaffs Sep 16 2008 09:34:42 Installing.
msgmni has been set to 1009
io scheduler noop registered
io scheduler anticipatory registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0xe0004500 (irq = 28) is a 16550A
                                                             console handover: b
oot [udbg0] -> real [ttyS0]
Gianfar MII Bus: probed
eth0: Gianfar Ethernet Controller Version 1.2, 00:0c:42:20:58:0c
eth0: Running with NAPI enabled
eth0: 256/256 RX/TX BD ring size
eth1: Gianfar Ethernet Controller Version 1.2, 00:0c:42:20:58:0d
eth1: Running with NAPI enabled
eth1: 256/256 RX/TX BD ring size
eth2: Gianfar Ethernet Controller Version 1.2, 00:0c:42:20:58:0e
eth2: Running with NAPI enabled
eth2: 256/256 RX/TX BD ring size
eth3: Gianfar Ethernet Controller Version 1.2, 00:0c:42:20:58:0f
eth3: Running with NAPI enabled
eth3: 256/256 RX/TX BD ring size
Driver 'sd' needs updating - please use bus_type methods
RB_PPC CF
CF: using Local-Bus clock 133332 kHz 7500 ps
CF: irq level 1
scsi0 : pata_rb_ppc
ata1: PATA max PIO6 irq 29
CF PIO mode changed to 0
RB_PPC CF
CF: irq level 1
scsi1 : pata_rb_ppc
ata2: PATA max PIO6 irq 30
RB_PPC NAND
NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 721 at 0x00b44000
Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00400000 : "RouterBoard NAND Boot"
0x00400000-0x04000000 : "RouterBoard NAND Main"
Registered led device: user-led
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
yaffs: dev is 32505857 name is "mtdblock1"
yaffs: Attempting MTD mount on 31.1, "mtdblock1"
block 466 is bad
VFS: Mounted root (yaffs filesystem) readonly.
Freeing unused kernel memory: 128k init
Starting...
VFS: Can't find an ext2 filesystem on dev mtdblock0.
yaffs: dev is 32505856 name is "mtdblock0"
yaffs: Attempting MTD mount on 31.0, "mtdblock0"
NET: Registered protocol family 17
flash: module license 'unspecified' taints kernel.
flash: starting...
flash: ptr = a1980000
flash_ioctl: get_flash_info(void)
flash_ioctl: get_soft_info(void)
flash: started
panicSaver: starting...
panicSaver: get_soft_ptr()=0x00010000
panicSaver: get_soft_size()=0x00001000
panicSaver: started
panicSaver_ioctl, cmd: 0x1, arg: 0x0
panicSaver_ioctl, cmd: 0x2, arg: 0x0
panicSaver_ioctl, cmd: 0x3, arg: 0x0
Starting services...
After downgrade to ROS v3.13 I got message:
RouterBOOT booter 2.16
RouterBoard 1000
  Memory size: 512 MB
Starting...
3.14 version problem will be fixed in the next release, 3.15 version should not put such information to console.
For 3.13 version, it looks like you set wrong baud-rate in Netinstall.
Try to use 9600, I assume it is baud-rage which goes on Netinstall program.
