rb1000-rb1100
why the cost diffrence
MT-RB1000 MikroTik RouterBoard 1000 - 512MB, 4 100/1000Mbps LAN & L6 License, Desktop 5,588.70
MT-RB1100U MikroTik RouterBoard 1100 - 512MB, 13 1000Mbps LAN Ports & L6 License, 1U Rackmount Case 4,386.00
if i look at thing the 1100u is better
then why the 1000 more then 1100u
South African rands
The RB1000 has a faster processor and hardware offloading for encryption.
so the 1000 is much better?
Depends on what you’re doing. Are you doing lots of encryption (SSL? IPSec?), or do you need the fastest possible processor? Then the RB1000 is probably better. The RB1100 has the two built in switch-chips, though, so if you can make use of them you get wirespeed switching at 1Gbps without any CPU penalty whatsoever.
