Have went back and forth with support a few times, sent multiple supouts and debug logs. Issue still persists.
~200ish SSTP tunnels to an RB1000, 5.18 and now 5.19, all 5.18 clients. RB450gs, 433ahs, 2011s… I run Amanda backup over the VPN links. So at peak load, its running about 40ish mbit download at about 30-40% cpu load.
The problem I keep having is.. randomly throughout the day, the RB1000 SSTP server will just stop working. There will be 200 active connections, then, poof, they all get dropped and 200 clients attempt to reconnect and “pending” interfaces are created, but they never get connected. All authentication is handled through FreeRADIUS. Authentication works fine. Redundant RADIUS servers on a local network to the router. All I have to do to get it to start working again is disable the SSTP server and re-enable it. All clients almost immediately reconnect with no issues.
This may happen 1-2 times a week, or 2-3 times a day. Seems to happen most often when there is heavy load on the router, but happens quite a bit when there is almost no load (~1mbit).
All I can say is.. I have had 3 years worth of VPN related problems with MT. OpenVPN being a problem, advised to use SSTP. SSTP going through many ups and downs, getting better, getting worse. Problems arising due to the # of connections I have increasing as customer base grows, new releases that fix problems and introduce new ones. I dont think I have had a completely STABLE version yet.
EDIT: To add. Ive stripped the router config down to bare essentials. I disabled ipv6, hotspot, wireless packages, manually disabled all dynamic routing protocols except BGP (Using it). Bare essentials of firewall rules. Like 6 rules, one nat rule and a mangle rule acting on the VPN IPs to clamp MSS. The SSTP server has a certificate w/ the IP of the router in the name, it verifies client certs. All clients have a cert and the CA installed. 2x RADIUS servers with mysql backend. Some routes set from RADIUS, nothing fancy. Maybe one /30 or /29 per client. 1 interface on the internet, 1 interface with 4 vlans attached to a managed switch. All other firewalling is done on the other side of the switch. It really is the barest possible config. I am running the NTP server package. I ended up doing this because I had more problems when I ran the SSTP server on the same router that I had IPSEC connections, queues, and hundreds of firewall rules. So I segmented it off. It helped, but didnt solve the problem. I have gone as long as 10-12 days without an issue, but more recently, it is happening at least every day, sometimes more often.
Is anyone else running upwards of 200 SSTP tunnels on a PowerPC routerboard? Successfully?
At this point, Im not even getting responses from support as I send them new supouts and logs. Really getting irritated. Has been 10 days since the last response from them saying other problems have been fixed.. Telling me pretty much nothing
