We just bought some Mikrotik hardware and I just read that the RB1000 is having IPSec tunnel dedicated hardware, thats pretty cool and would really benefit from that. I would like to know which tunnel are supported by this feature, is PPTP, OVPN, L2TP and IPsec use the offloading engine?
Also, would like to know if dynamic tunnel are now supported since most of our remote site have dynamic IPs. Can someone point me out a tutorial on how to establish a really simple tunnel using a RB450 with dynamic IP and a RB1000U with a static IP.
We allready put v4.0b3, should we go back to v3.27 , we had no issue yet with the beta.
Will experiment with pptp, but some says it is less secure than Ipsec, would I achieve higher perfomrance using pptp on my RB1000?
But like I said would like prefer using IPSec hardware offloading feature of the RB1000. So is dynamic IP supported at the remote location, using RB450?
I followed the Ref manual v3 example IPsec Between two Masquerading MikroTik Routers, but the tunnel is not building up. Do you have some info in the manual on how to diagnose my issues with logs?
Those are very good info and pointers I will try as soon as my vacation are over. Again, can someone with good knowledge in tunnelling technology using Mikrotik router would be able to give me a very easy to understand pros and cons of each of them, like I said we plan to use a pure Mikrotik solution from site to site and some mobile users, mostly for admin task may need to connect inside the VPN too. Performance is important since we are planning 4000 tunnels from different micro sites (1 to 5 users) on our RB1000 using RB450.
ahrg, usually I’m pretty good without needing to ask spoon feeding me the procedure. But again I’ll need help and hopefully this will be helpfull for some other people. I deleted the policy on the remote site and check the generate policy, that works, but strangely it created not one, nor two but three Dynamic policy on the primary site with only one remote MT 450 establishing the connection.
As soon as I change, in the primary site, the IP address of the peer to 0.0.0.0, and the SA Src Address in the remote policy to 0.0.0.0 I get into trouble… I read again the ref manual and try to change the policy level to other settings without better result…
