RB1000 Watts?
Anyone has the watts consuption for this unit?
It’s uses 12V 3A PSU… so MAX 36W
thanks, anyone knows if it can accept 18 or 24 vdc?
Theoretically - yes, but both 12V Fans connected in paralel to Main input. If you want use 24V you need limiting Fan feed voltage put in serial something like Zener diode.
for production use i would recommend 12V supply.
