I’m running RouterOS v5.18 with an RB1100 AHx2.
I noticed from the interface>ethernet>print output:
[admin@MikroTik] > interface ethernet print
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 ether1 1500 D4:CA:6D:20:6D:EF enabled
1 ether2 1500 D4:CA:6D:20:6D:F0 enabled
2 R ether3 1500 D4:CA:6D:20:6D:E4 enabled none switch2
3 ether4 1500 D4:CA:6D:20:6D:E5 enabled none switch2
4 ether5 1500 D4:CA:6D:20:6D:E6 enabled none switch2
5 ether6 1500 D4:CA:6D:20:6D:E7 enabled none switch2
6 ether7 1500 D4:CA:6D:20:6D:E8 enabled none switch2
7 ether8 1500 D4:CA:6D:20:6D:E9 enabled none switch1
8 ether9 1500 D4:CA:6D:20:6D:EA enabled none switch1
9 ether10 1500 D4:CA:6D:20:6D:EB enabled none switch1
10 ether11 1500 D4:CA:6D:20:6D:EC enabled none switch1
11 ether12 1500 D4:CA:6D:20:6D:ED enabled none switch1
12 ether13 1500 D4:CA:6D:20:6D:EE enabled
[admin@MikroTik] >
the strange thing is that I’m connected to the physical port 1 on the routerboard (so I guess port 0 ether1 should be running) but the output says ether3 (index2) is running.
It seems as if there’s a mismatch between physical ports and connected interfaces.
I noticed these behavior on 3 differente RB 1100AHx2.
Anyone with such a problem?
Thank you
Regards
snapshot:
[admin@MikroTik] >
Thank you
Regards
Port numbering is often a problem with Mikrotik. Please send this to support@mikrotik.com so they can fix it in the next update.
jandafields and snapshot, thank you very much for the report.
The problem is fixed at MikroTik RouterOS 5.19 version, that is being tested for release.
Hi sergejs, do you have an idea of when the v5.19 will be out?
Thank you
Thanks guys!
This has been driving me insane. Every time I reboot a RB1100AHx2 with eth11/12 as bonding slaves they change and break the bond
v5.19 is being tested intensively at the moment, it should be released very soon.
If you like to get the newest release candidate version (with the fix for the particular problem), contact us (support@mikrotik.com ). We will give you “rc” packages.
