i would like to know if a 64Gb microSDXC card is compatible with a RB1100 before i can purchase it.
I’d really appreciate a response.
Hi, currently I’m using SanDisk 64GB microSDXC card and it doesn’t seem to work. System > Stores > Disk shows the microSD as invalid and formatting takes a very long time. After being fed up of waiting, I rebooted the router and the microSD card doesn’t seem to be recognized anymore. Bummer..
I use a 16 GB MicroSDHC is my 1100AH for log and file storage and it works. Formatting takes a long time, but after that, it works great.
After reading tomaskir’s comment, I shut down my router, rebooted it and reformat the card. Now I can confirm that SanDisk 64GB microSDXC is indeed compatible with RB1100AHX2!
Oh the web-proxy is now working beautifully! ![]()
