We’ve had issues trying to peer with another provider who uses a Juniper switch. Patching from the Juniper gigabit port to the RB1100 results in the Mikrotik freezing almost immediately.
We tried different ports 8,10 and 12 all with the same results. To bypass the issue we manually set the port speed at 100Mbps and it seems stable at the moment. Testing on the unit is very limited as it controls a major part of the network.
I would like to change back to gigabit speed ASAP so I was wondering if anyone out there has seen similar issues or knows how to fix it.
Cheers,
Dan
