we are using ether13 on a RB1100 for local Management. It just has a ip address and a dhcp-server configured. My colleague connected his laptop to the port and everything was ok. Then later he disconnected the cable and after some time the whole box was freezing (serial console was also dead!).
We then replaced the whole box by a new one (we thought that it might be a hardware problem) .. he had his laptop connected for 40 mins and everything was fine .. then he disconnected it and it crashed again.
I know that ether13 is labeld with “PoE / Boot” but we thought that it would be ok to use it (while normal power is connected via the internal power supply).
One time i saw cpu going to 100% after he disconnected his cable from the port … i disabled / enable ether13 and CPU usage went back to normal and it didn’t crash!
it doesn’t only happen with port 13, port 11 and 12 are the same. I had that trouble before but i thought that it could be faulty memory that i used or dodgy firmware. Now i have tried ROS 4.16 and original memory and it still happens.
This is really annoying … i hope MT is able to fix that by software/firmware update … so we can not use 1100 as planned in a production environment … damn
I have the same issue, however nailed it down to one device → my Philips Skype phone.
All other devices work fine - if I unplug that one - and plug it back in - all connectivity goes - and sometimes it reboots the router.
Note this is also valid - if I reboot the base station (power cycle).
The Network-Lock/reboot happened on a RB493AH and still happen on a RB493g (the AH had a ethernet port issue / broken, hence I replaced it).
Just got and installed a RB1100, and have found the same issues…
Anytime something is disconnected from ports 11-13 the rb1100 crashes and the only way to recover is by rebooting.
Has there been any word from MT as to a solution for this?
I was using port 13 to connect a laptop for administration and when done disconnect then finding out the RB was locked up and crashed.
I wish I would have found these posts regarding the crashing with ports and also the performance issues before making my purchase. I had read a while back how great this box was going to be and ordered one, that ended up back ordered. It finally showed up and I got it installed and now I find all these issues are posted…
I guess if this isn’t solved soon I will be going to another solution. Its bad when the manufacture is aware of a problem like this and still continues to sell the product without notifying the purchaser that there is a problem like this one.
I hope that it will get fixed in 4.x also since we have a lot of RB1100 in production environments and we are not willing to use a development version there …
