i am trying to setup the date and time manually on my RB1100, every time when i restart the box date and time return to it is original setting year 2002!
is that normal? i mean i am not using NTP client and why should i ?!
i Really dont understand the concept behind using NTP only! at least you could keep the tame saved on the local disk before it ReSync with NTP server!
NTP takes time to reset system time after rebooting the system, what happen to user manager and Hotsopt during this time? they will give false login response!
as often as i need to install new update!
despite the often rebooting, are you sure that running “user manager” service with wrong date and time would not affect the database even if no users trying to connect? what about graphing? what if the NTP server toke more that 3 sec? what if the internet was down for some reason!
again i am talking about system rebooting where the board remain powered so you dont need a battery to beep time running correctly!
from my point of view keeping time saved is essential for people using router board as hotspot with usermanager
If internet is down, User Manager does not work/HotSpot does not work.
There will be correct data for graphs after reboot, http://demo2.mt.lv/graphs/cpu/
however you can use remote SNMP collector to get the most precise information.
To whom it may concern, this script will save time and date every 10 sec and apply it after system reboot till system get SYNC with NTP Client
the script will create 2 disabled users account [date] and [time] only to keep record of date and time.
Just paste this code in your router terminal
/system script
add name=fixclock policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source=\
"/system clock set date=[/user get date comment]\r\
\n/system clock set time=[/user get time comment]"
add name=setclockfix policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source=":if ([:pick [\
/system clock get date] 7 30]>=[:pick [/user get date comment] 7 30]) do={\r\
\n/user set date comment=[/system clock get date]\r\
\n/user set time comment=[/system clock get time]\r\
\n}\r\
\n"
/system scheduler
add comment="" disabled=no interval=0s name=fixclock on-event=fixclock policy=write,test start-time=startup
add comment="" disabled=no interval=10s name=setclockfix on-event=setclockfix policy=write,test start-date=\
jan/01/1970 start-time=00:00:00
/user
add address=1.1.1.1/32 disabled=yes group=read name=date
add address=1.1.1.1/32 disabled=yes group=read name=time
I still don’t understand why this matters. When router has been rebooted, nothing works anyway, and when it comes up, the logs and graphs are not disturbed by those few seconds of year 1970
when i reboot my router NTP it needs at least 20 sec to Resync i have more than 100 users authenticate over userman so i dont want to take this risk. unless you tell me that no service will start until date get synchronized?!
NTP gets synced not much more after the wireless drivers load, so there is no big outage. Just check yourself! Do a reboot and see how many log lines have incorrect date!
If there are no immediate log entries after a reboot, its also nice to see in the logs exactly what time a router rebooted instead of having to calculate the uptime.
@normis: ever thought about how it would be nice to know when a “unwanted reboot, probably power outage?” happened?
That’s what you need a clock battery for…
if I connect to a router which has had several power outages, all of them are shown as 1.1.1970 at 02:00:02 … very helpful… not.
I too think that putting RTC and a battery in at least higher-end RBs wouldn’t hurt Why should you suffer any inconveniences?
Besides, there are some bugs in RouterOS itself that has not yet been fixed and seems like it’s not going to be.
Like this one for example: http://forum.mikrotik.com/t/cannot-get-challenge/30069/15
Here is your answer for “why would you want to reboot your router very often?”.
