I´ve bridged both ports with a software bridge (hardware bypass mode is off).
I enabled the “Use IP Firewall” feature on the bridge, added a few mangle rules and a queue tree.
Immediately after enabling the queue the ports go on/off every few seconds - dropping my connections and make them practically unusable. If i move the same configuration to other ports (lets say port 6/7), everything works as expected.
If i disable the queue tree, everything works on those ports; So it definitely happens only on those 2 ports and only if queue is enabled.
I have everything running (including queue and complex rules) on port 6/7 - whithout any issues.
I have no idea why that issue show on those ports only. Anybody knows?
Thanks.
Edit: It may be helpful to add, that i already disabled auto-neg and full-duplex without any result.
Strangely it doesn´t happen, if i disable queue on these ports.
The ports were up and running for about a week (pushing ~8Mbit of traffic), before i enabled the queue tree today.
So i had no issues before.
Yes, i upgraded to 4.11; this fixed an issue with ports still showing traffic after pulling off the cable.
This happened pretty much everytime, i pulled out the cable from Port 13 (i didn´t test the other ports, because it didn´t seem to hurt in any way).
But i did´t do anything with the issues described above; I tested with 4.10 and 4.11 - no change.
I had the same problem when I connected to a switch port11,12 connected without problem, but when I connected to a pc,in this case a wimax antenna, it disconnects and connects every momemnt, I tried deactivating the auto negotiation, even with 10/100 and full duplex…
